[Qgis-developer] weekly build problem
Angie Rudolph angie at greenwoodmap.com
Wed Oct 15 06:13:36 PDT 2014
After uninstalling all my plugins, renaming my .qgis2 folder nothing had
changed.  So I uninstalled QGIS, deleted any remaining QGIS folders
including .qgis2 and  purged everything from my registry settings.
Everything is working again.   Thanks for you input.
HKEY_CURRENT_USER\Software\QuantumGIS
HKEY_LOCAL_MACHINE\Software\   I had several QGIS installations here that I
had to delete.
Angie Rudolph, GISP
Greenwood Mapping, Inc.
c:(208)-201-5699
On Tue, Oct 14, 2014 at 11:56 PM, Mathieu Pellerin <nirvn.asia at gmail.com>
wrote:
> Rename your .qgis2 folder in your user profile directory (eg
> c:\users\my_name\.qgis2) to something else to try a vanilla qgis
> configuration. If speed goes back to normal, problem lies with a plugin, or
> less likely a non-default qgis setting.
> M
> On 15 Oct 2014 12:52, "Stott, James" <fmrojst at fylkesmannen.no> wrote:
>>  Are there any plugins that could be causing this problem? Seeing as the
>> problem exists over 2 different versions of QGIS I would recommend checking.
>> I have had similar (think it was with version 2 and 2.2) and the problem
>> was solved by turning off all plugins. I was then able to add the plugins
>> in again one by one to find the plugin causing the problem.
>> *Fra:* qgis-developer-bounces at lists.osgeo.org [mailto:
>> qgis-developer-bounces at lists.osgeo.org] *På vegne av* Angie Rudolph
>> *Sendt:* 15. oktober 2014 01:17
>> *Til:* qgis-developer at lists.osgeo.org
>> *Emne:* [Qgis-developer] weekly build problem
>> I installed the windows weekly build on 9/26/14 and QGIS has been
>> behaving poorly ever since.  When I add
>> a simple shapefile, stored on my local hard drive, turning the layer off
>> an on takes up to 10 seconds.
>> I have since tried to uninstall the weekly build and install a stable
>> version of QGIS (2.4) but the problem now remains.
>> Is there something else that needs to be uninstalled such as visual C++,
>> etc?
>> Angie Rudolph, GISP
>> c:(208)-201-5699
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141015/ef492451/attachment.html>
