[Qgis-developer] Print composers: should locked elements be selectable?
Andreas Neumann a.neumann at carto.net
Wed Oct 15 13:23:35 PDT 2014
Hi Nyall,
I guess I was just used to the old behavior.
I have a lot of print composers with locked items (to avoid accidental
movements) and was used to the fact that I could still select the locked
items ...
I guess I will get used to the new behavior. Please leave it as it is.
Andreas
On 15.10.2014 22:14, Nyall Dawson wrote:
> Hi Andreas,
> On 16/10/2014 1:00 am, "Andreas Neumann" <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> > In QGIS 2.4 locked elements where still selectable in the canvas, in
> 2.6 they are not, but one can still select them in the element list.
> This is intentional and something I've been coding towards for a long
> time (it was actually my first ever frustrating behavior i ran into
> with QGIS' composer back when I started using QGIS!).
> Here's the rationale:
> - it brings QGIS into line with the standard behavior of
> illustrating/DTP software. This is a big plus in itself...
> - it makes it possible to interact with items which are stacked below
> other items. Otherwise, its impossible to click and drag an item which
> has something above it. Making locked items non-interactive in the
> canvas means that you can lock the upper item, freely move/resize the
> lower, and then unlock the upper item again.
> - the items panel makes it easy to select locked items and also
> quickly unlock them.
> Unless a bunch of angry users turn up at my house with pitchforks and
> flaming torches this change is here to stay! ;)
> Nyall
> > To me, the locking mechanism mainly prevents unwanted movement of
> elements and I personally would prefer that locked elements are still
> selectable in the canvas. It would be different if we had the concept
> of layers. Elements in locked layers should not be selectable, I think
> - but since we do not have layers yet, I am not sure ...
> > What are the opinions?
> > Andreas
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141015/f5e70fe6/attachment.html>
