[Qgis-developer] New processing manage fields algorithm
    Victor Olaya
    volayaf at gmail.com
    Mon Oct 20 08:26:41 PDT 2014
That's definitely a nice idea. I guess this was what you started working on
at the Hackfest but i wasn't of much help since i wasn't understanding the
idea completely... :-(
Here are some suggestions:
- There are some algorithms that have a custom UI and that you can take as
example. The vector calculator is probably one of them
- You will need to create a custom UI for the modeler as well, in case you
want to appear with a nicer dialog than the default one. Processing
supports that, but there is no algorithm currently using it. I can take
care of that once you have the basic UI finished
- Sounds like it would be a nice algorithm to have for editing a layer.
That is, to modify it instead of generating a new one. You can do that by
not having a visible output layer in the UI, and just returning the input
layer source path instead as output value.
Let me know if you have questions.
Regards
2014-10-20 16:52 GMT+02:00 Arnaud Morvan <arnaud.morvan at camptocamp.com>:
> We want to create a new processing algorithm for manage table fields.
> This new algorithm would have :
>     one standard input layer vector parameter
>     one standard output layer vector parameter
>     a specific fields mapping parameter composed, in columns
>         source field name (optionnal)
>         destination field name
>         destination type, length, precision
>         expression (default to the source field name)
>     the mapping would be initialized, when possible, with the input layer
> fields.
> In the dialog :
>     the first tab would present the normal input/output parameters and a
> button to go to the next tab
>     the supplementary fields tab would contains the fields mapping
> The final goal is to supply a user friendly interface to manage table
> fields :
>     rename fields
>     change field types
>     add new fields based on expression
>     change fields order
> and save the result as a new file, temporary file or memory layer
> What do you think about this ? Any remarks ?
> Arnaud
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141020/3a01fb3e/attachment.html>
