[Qgis-developer] Troubles with actions
Andreas Neumann
a.neumann at carto.net
Thu Oct 23 05:36:41 PDT 2014
I have troubles with actions - testing with current master (nightly) on
Win7 64bit.
Often QGIS either crashes when using the action or the action is started
but not with the correct attribute value.
The action starts a Java application with a given parameter set. When
QGIS does not crash, the Java app is correctly started, but the
parameter (a database key) is often omitted.
Did others test the current master with their actions (on Win7 64bit)?
Thanks,
Andreas
