[Qgis-developer] Troubles with actions
Denis Rouzaud denis.rouzaud at gmail.com
Thu Oct 23 07:18:19 PDT 2014
Hi Andreas,
Do you say that the same project/workflow does not crash on linux and is
specific to windows or have you haven't tested this on linux?
If you haven't, by any chance, can you try and give more details where
the crash occurs?
Best wishes,
Denis
On 23.10.2014 14:36, Andreas Neumann wrote:
> Hi,
> I have troubles with actions - testing with current master (nightly)
> on Win7 64bit.
> Often QGIS either crashes when using the action or the action is
> started but not with the correct attribute value.
> The action starts a Java application with a given parameter set. When
> QGIS does not crash, the Java app is correctly started, but the
> parameter (a database key) is often omitted.
> Did others test the current master with their actions (on Win7 64bit)?
> Thanks,
> Andreas
> Qgis-developer mailing list
