[Qgis-developer] Troubles with actions
Andreas Neumann
a.neumann at carto.net
Thu Oct 23 07:48:38 PDT 2014
I don't have this software on Linux, that I am starting with the action.
The crash happens quite unpredictable. Sometimes it starts correctly,
sometimes the other software starts, but the parameter is missing,
sometimes it crashes.
If the crash happens, it happens immediately after I trigger the action.
Does the minidump file help at all?
Andreas
On 23.10.2014 16:18, Denis Rouzaud wrote:
> Hi Andreas,
> Do you say that the same project/workflow does not crash on linux and
> is specific to windows or have you haven't tested this on linux?
> If you haven't, by any chance, can you try and give more details where
> the crash occurs?
> Best wishes,
> Denis
> On 23.10.2014 14:36, Andreas Neumann wrote:
>> Hi,
>> I have troubles with actions - testing with current master (nightly)
>> on Win7 64bit.
>> Often QGIS either crashes when using the action or the action is
>> started but not with the correct attribute value.
>> The action starts a Java application with a given parameter set. When
>> QGIS does not crash, the Java app is correctly started, but the
>> parameter (a database key) is often omitted.
>> Did others test the current master with their actions (on Win7 64bit)?
>> Thanks,
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
