[Qgis-developer] Troubles with actions
Denis Rouzaud denis.rouzaud at gmail.com
Thu Oct 23 07:59:21 PDT 2014
On 23.10.2014 16:48, Andreas Neumann wrote:
> Hi,
> I don't have this software on Linux, that I am starting with the action.
> The crash happens quite unpredictable. Sometimes it starts correctly,
> sometimes the other software starts, but the parameter is missing,
> sometimes it crashes.
> If the crash happens, it happens immediately after I trigger the action.
It's a bit hard to tell from this. I observed some crashes when running
actions a few months ago, but nothing since.
 From where do you launch the actions (new identify menu, identify dock,
feature form)?
> Does the minidump file help at all?
I don't have the environment to inspect it.
> Andreas
> On 23.10.2014 16:18, Denis Rouzaud wrote:
>> Hi Andreas,
>> Do you say that the same project/workflow does not crash on linux and
>> is specific to windows or have you haven't tested this on linux?
>> If you haven't, by any chance, can you try and give more details
>> where the crash occurs?
>> Best wishes,
>> Denis
>> On 23.10.2014 14:36, Andreas Neumann wrote:
>>> Hi,
>>> I have troubles with actions - testing with current master (nightly)
>>> on Win7 64bit.
>>> Often QGIS either crashes when using the action or the action is
>>> started but not with the correct attribute value.
>>> The action starts a Java application with a given parameter set.
>>> When QGIS does not crash, the Java app is correctly started, but the
>>> parameter (a database key) is often omitted.
>>> Did others test the current master with their actions (on Win7 64bit)?
>>> Thanks,
>>> Andreas
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
