[Qgis-developer] Troubles with actions
Andreas Neumann
a.neumann at carto.net
Thu Oct 23 08:14:52 PDT 2014
BTW:
Here is the action I use:
"C:\Program Files (x86)\DataverAbwasser\jre\bin\java.exe" -jar
"\\srv141\Stadtentwaesserung\sbu\a2dv\av2dv.jar"
-conf="F:\Data\Programme\Dataver\av2dv.conf" -typ=K -bez=[% "haltungsnr"
The "haltungsnr" is the dynamic attribute that should be handed over to
the other application. In 80% of the cases it fails, in some cases it
works with correct values. I double checked that the values exist.
Very strange.
Andreas
Am 2014-10-23 17:04, schrieb Andreas Neumann:
> The question besides the crashes is why in many cases the parameter
> (attribute values) is not correctly handed over in the action?
> Very strange ...
> Andreas
