[Qgis-developer] error when saving modified features via wfs-t/qgis server
Giovanni Manghi giovanni.manghi at faunalia.pt
Thu Oct 23 06:12:18 PDT 2014
Hi all,
I'm noticing the following when editing features via wfs-t (with qgis
as client and as server): if the modified feature has a lot of nodes
then saving give this error
Errors: ERROR: 1 geometries not changed.
Provider errors:
empty response
if I simplify/generalize the feature then (at some point after
generalizing quite a lot) modifying/saving via wfs-t works ok.
Adding/deleting features operations are not affected.
I tested both qgis 2.4 and master both as client and server using both
shapes and postgis as source data.
Is this a known limitation?
cheers!
Giovanni Manghi
Faunalia.pt
Sistemas de Informação Geográfica Open Source
Portugal
Web: http://www.faunalia.pt
Email & Jabber: giovanni.manghi at faunalia.pt
PGP Key available
Tel. + 351 96 7058216
