[Qgis-developer] Legend-tree: Category checkboxes behave strange on Linux/KDE
Martin Dobias
wonder.sk at gmail.com
Thu Oct 23 22:31:14 PDT 2014
Hi Andreas
This should be fixed in 8db77f. Let me note that the problem may
happen only with rule-based renderer where some rules have been copied
(to create new rules) while using qgis master. It should not be
linux/kde specific.
Projects where this problem appears need to be fixed by the user - the
easiest way is to select all rules, copy&paste them and remove the
previous rules. This will rewrite their non-unique identifiers to
unique.
Cheers
Martin
On Thu, Oct 23, 2014 at 8:28 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> Is there someone who tests QGIS master on Linux/KDE?
> I have issues with the new legend tree and the "pseudo-layers" (category
> checkboxes). Normally a checkbox needs a mouse-click in order to toggle. In
> the legend-tree on Linux/KDE it seems like if I check one checkbox with the
> click and then mouse-over other checkboxes, the checkbox-statechange already
> happens on mouseover. This is very suboptimal.
> Apparently only the checkbox state is toggled, but not the action associated
> with the checkbox - thus the legend-tree gets out of sync ...
> I wonder if others have the same issue? Testing on Kubuntu 14.04 / KDE
> desktop.
> Andreas
> Qgis-developer mailing list
