[Qgis-developer] Vector equivalent of a VRT
Tim Sutton
tim at kartoza.com
Sun Oct 26 03:35:29 PDT 2014
Hi
On Oct 24, 2014 6:51 PM, "Andre Joost" <andre+joost at nurfuerspam.de> wrote:
> Am 24.10.2014 um 17:08 schrieb Tim Sutton:
>> Hi
>> On Oct 24, 2014 4:43 PM, "Zoltan Szecsei" <
zoltans-MBOXMv9ChCPu3wEYkePUmQ at public.gmane.org> wrote:
>>> On 2014/10/24 16:36, Andre Joost wrote:
>>>> Am 24.10.2014 um 16:16 schrieb Zoltan Szecsei:
>>>>> Hi All,
>>>>> I've been googling around, but cannot find what I'm hoping for.
>>>>> Is there a VRT implementation for vector data?
>>>> Surely:
>>>> http://www.gdal.org/drv_vrt.html
>>>> unfortunately, there is no easy-to use transformation for it.
>>>> From the page:
>>>>> The virtual files are currently normally prepared by hand.
>>>> And hence QGIS can not save into that format.
>>>> HTH,
>>>> André Joost
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer-qjLDD68F18NyQMAyxoHuMA at public.gmane.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Yep. Looking at it now - thanks Alexia as well.
>>> -1 for me not trying harder before posting :-)
>> Make that -2 for forgetting that someone mentioned the fact that you can
>> have vector vrt's to you before on the QGIS mailing list :-)
> +100 from me if you promise to build a QGIS plugin for the purpose ;-)
> Greetings,
> André Joost
We could build something - at least for the use case where you want to
create a mosaic of shp files that have the same attributes... But i have to
wonder if there is much point - just importing them into spatialite or
postgis seems like a much nicer approach. You could always dump out
spatially separated shapefiles again from postgis.
Regards
Tim
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141026/ff30acfe/attachment.html>
