[Qgis-developer] Problems when editing the attribute table
Ramon Andiñach
custard at westnet.com.au
Wed Oct 29 15:13:22 PDT 2014
On 30/10/2014, at 24:38 , Frank Sokolic wrote:
> On 29/10/2014 18:21, Pedro Venâncio wrote:
>> Hi,
>> There's a thing that happens to me when I'm editing the attribute table
>> of layers (both PostGIS and shapefiles) in QGIS.
>> I change the content of one (or more) fields, but the content displays
>> the same. I save the editions and continues to show the old value. To
>> see the changes, I have to close and re-open the attribute table.
>> I've confirmed and this happens to many people. I confess I've noticed
>> this from some versions ago (including the current master), and I think
>> I got used to it, but it is certainly a bug.
>> As it is a situation that is not easy to replicate, because does not
>> always happen, I can not open a ticket with truly useful information.
>> What do you think?
>> Best regards,
>> Pedro Venâncio
> Hi Pedro,
> Is this the same is this bug?
> http://hub.qgis.org/issues/10976
> Regards, Frank.
Pedro, Frank,
Thanks for pointing that bug out - I've added a bit to it.
Over the last week I've noticed that if I just open the table and change things, it refreshes fine -
but if I open the table, sort it, then change things the refresh breaks.
Is that pattern repeatable for you?
-ramon.
