[Qgis-developer] [Qgis-tr]  size of translations,	use a distinct repo?
    Werner Macho
    werner.macho at gmail.com
    Thu Oct 30 09:12:31 PDT 2014
Hi!
I am sorry for not realizing that :(
But from now on it should be much better ..
Other thing is that I think about only updating all translations in
source only every two weeks (or probably only in front of a release)
as the translation should be done in transifex anyway. And only
updating the english source in transifex (and master of course).
Pros: even smaller and less commits,
Cons: Some translators often like to see "how it looks like" and I
understand that from time to time you want to see if "it fits".
What do you think about that?
regards
Werner
On Thu, Oct 30, 2014 at 4:28 PM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi Werner,
> Thanks for this, indeed last translation commit is indeed much smaller!!!!
> Less than 1k lines while it used to be about 50k before.
> Cheers,
> Denis
> On 29.10.2014 20:49, Werner Macho wrote:
>> Hi!
>> I added the suggestion from jef and tried the new produced ts files in
>> linguist and transifex without any problems ..
>> So I decided to update everything again (with strings and transifex
>> update) ..
>> ts files should now have no location inside any more ..
>> I hope that shrinks down the size from now on.
>> regards
>> Werner
>> On Wed, Oct 29, 2014 at 2:56 PM, Stott, James <fmrojst at fylkesmannen.no>
>> wrote:
>>> As a slight side point, according to transifex it looks like we could
>>> have 13 fully translated languages for the GUI by the time 2.6 is released
>>> (13 languages are on 99% or more). 15 languages are over 95%. This is
>>> excellent news.
>>> Is it something we should publise, maybe add to the visual changelog?
>>> -----Opprinnelig melding-----
>>> Fra: qgis-tr-bounces at lists.osgeo.org
>>> [mailto:qgis-tr-bounces at lists.osgeo.org] På vegne av Werner Macho
>>> Sendt: 29. oktober 2014 14:15
>>> Til: Denis Rouzaud
>>> Kopi: QGIS Translation Discussions; qgis-developer
>>> Emne: Re: [Qgis-tr] [Qgis-developer] size of translations, use a distinct
>>> repo?
>>> hmm - ok ..
>>> Then I am going to give it a try without location and see if there are
>>> any problems with transifex or linguist ..
>>> If not - I also think that way is perfect ..
>>> regards
>>> Werner
>>> On Wed, Oct 29, 2014 at 2:11 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
>>> wrote:
>>>> On 29.10.2014 14:06, Werner Macho wrote:
>>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>>> Hash: SHA1
>>>>> Good idea,
>>>>> if its really translation that causes the growth we should do
>>>>> everything to avoid that.
>>>> As Jurgen noticed, there are some useless changes in the ts files:
>>>>       <message>
>>>> -        <location filename="../src/core/qgscontexthelp_texts.cpp"
>>>> line="327"/>
>>>> +        <location filename="../src/core/qgscontexthelp_texts.cpp"
>>>> line="319"/>
>>>> if there are lines removed/added in the source file, this will cause
>>>> changes in the translation file.
>>>> Jurgen suggested to remove these tags "location filename" which would
>>>> improve a lot.
>>>>> Is there any way to "shrink" the already existing repo?
>>>>> At one point I thought about zipping the ts files - but if there is a
>>>>> better way .. good!
>>>>> I always wondered why the whole translations file has to be changed
>>>>> whenever there are only some small changes ..
>>>>> moving the translation in it's own github repository: hmm - I don't
>>>>> know if thats easily possible.. but I am also willing to try it if it
>>>>> helps the source code to stay clean.
>>>> I don't see any reason why it wouldn't be possible.
>>>> git submodules would be pretty useful for this matter.
>>>>> But again - anyway to shrink the already existing source code?
>>>> As far as I know, you can't shrink existing repo without destroying
>>>> the history.
>>>>> I don't mind about loosing track of translation changes.
>>>>> regards
>>>>> Werner
>>>>> On 10/29/2014 12:15 PM, Jürgen E. Fischer wrote:
>>>>>> Hi Denis,
>>>>>> On Wed, 29. Oct 2014 at 11:08:16 +0100, Denis Rouzaud wrote:
>>>>>>> Any thoughts?
>>>>>> I guess this is just due to the "location filename" stuff.  That
>>>>>> often causes massive change in the ts files, because lines were
>>>>>> added or removed from the source files - even if there isn't even a
>>>>>> changed translation.
>>>>>> I think that is not used at all for transifex and it's not that
>>>>>> important to have in linguist either.
>>>>>> So instead of inventing something new, all it takes might be to add
>>>>>> "-locations none" to our lupdate call, reduce the size of the .ts
>>>>>> files a lot (in one huge commit) and avoid useless tracking of
>>>>>> location changes in the future.
>>>>>> Objections?
>>>>>> Jürgen
>>>>>> _______________________________________________ Qgis-tr mailing list
>>>>>> Qgis-tr at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
>>>>> -----BEGIN PGP SIGNATURE-----
>>>>> Version: GnuPG v1.4.15 (GNU/Linux)
>>>>> iEYEARECAAYFAlRQ5k8ACgkQDAH1YiCxBgn7TQCeKllHCgzKm1Jn2iRT6iwPXkPd
>>>>> qmsAnjjWeXZySoZX9WQYf82w4s64s2ql
>>>>> =AGCZ
>>>>> -----END PGP SIGNATURE-----
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
