[Qgis-developer] qgis2threejs issue
Paolo Cavallini cavallini at faunalia.it
Fri Oct 31 02:22:41 PDT 2014
Il 31/10/2014 09:58, Minoru Akagi ha scritto:
>> That would be appropriate IMHO. Should I open a ticket?
> Yes, please.
done
> You need to take some steps. Do not change view extent of map canvas
> while these steps:
> 1. save the map canvas as a PNG image.
> 2. set the background color as PNG transparent color using a photo
> editor. I used IrfanView for this purpose.
> 3. in the plugin dialog, select the image file option in the display
> type group and enter the file path in the edit box.
> 4. set transparency to 1% to enable transmission, and uncheck the
> build sides option.
> 5. do export
works smoothly, thanks. IMHO it would be better to make all this automatic.
should I open another ticket?
All the best, and arigatou.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
