[Qgis-developer] SVG Export from print composer as raster?
Andreas Neumann
a.neumann at carto.net
Wed Sep 3 07:10:06 PDT 2014
I noticed that SVG symbols (from point and pattern symbology) from print
composer are exported as raster when exported as part of the map and
from the legend item. However, SVG images from the image/photo item are
exported as vector. This in both SVG and PDF format.
Ideally, all could be output as vector.
Is there anything we can do about it that legend items and maps are all
output as vectors?
Thank you if you know anything about it.
Andreas
