[Qgis-developer] Proposal: move the "Remove layer(s)" button
aperi2007 aperi2007 at gmail.com
Fri Sep 5 23:03:53 PDT 2014
I guess in a GIS oriented product
Is necessary to avoid to mix the interface characteristics (the group is
an interface object) and the data characteristics (the shapefile is not
an interface object).
I guess more beter if add/remove dataset is separated phisically from
add/remove a group.
The dataset is a phicical think. The shapefile is using separately from
the qgis project.
The group is not separately from qgis project.
I guess is good question to have a "remove group" but avoiding to have a
only button "ADD Everything" or an only button "Remove everything"
Also I guess is important to help to understand when we are on dataset
(physical) and when we are on interface (logical).
Regards,
A.
Il 06/09/2014 07:10, Mathieu Pellerin ha scritto:
> Greetings,
> I'd like to circulate a UX proposal and see how people react.
> For a very long time, QGIS' Layers toolbar has featured a "Remove
> layer(s)" button. I have seen two issues with the button:
> - Its placement becomes really odd when plugins add button(s) to the
> Layers toolbar (for e.g. the New Memory Layer plugin as pictured here
> [ http://imgur.com/CEcIC3K,QvUzrti ])
> - It can only remove vector/raster layers, won't remove groups
> With the recent improvements done by Martin Dobias on the legend, and
> in particular with his addition of a layer panel embedded toolbar, I
> propose that:
> - The "Remove layer(s)" button be moved to the layer panel embedded
> toolbar [ http://imgur.com/CEcIC3K,QvUzrti#1 ]
> - The button functionally is improved so it can also deal with the
> removal of group(s)
> Alternatively, we could get rid of the button altogether since layers
> and groups can be removed via right click or keyboard shortcut, but I
> suspect the touch screen based users might object.
> Any objection to moving the button to the new layers toolbar?
> Math
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140906/72e16b2c/attachment.html>
