[Qgis-developer] Best IDE for LMDE ?
A Huarte ahuarte47 at yahoo.es
Wed Sep 10 12:06:31 PDT 2014
I have experience using Eclipse for java development, but your advices give me the answer. I will use QtCreator, it seems awesome!
Thank you very much Matthias and Larry !
Best Regards
Alvaro
>________________________________
> De: Larry Shaffer <larrys at dakotacarto.com>
>Para: QGIS Developer List <qgis-developer at lists.osgeo.org>
>Enviado: Miércoles 10 de septiembre de 2014 20:53
>Asunto: Re: [Qgis-developer] Best IDE for LMDE ?
>Hi,
>I use Qt Creator as well. The context help immediately available to all the Qt classes saves a lot of time. I use Creator on all the major platforms, in virtual machines, and it works equally well on all.
>Eclipse has the advantage of doing your PyQGIS dev in it too. I prefer PyCharm, but the new Community (free, open source) version no longer offers the remote debugging for plugins running inside QGIS. It is only in the 'pro' version. Whereas, this is still available via PyDev plugin on Eclipse.
>Regards,
>Larry
>On Wednesday, September 10, 2014, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
>Hi Alvaro,
>>After I initially worked with eclipse, I switched to Qt Creator and
>>like it very much for it's integration with the Qt data types and
>>getting running is as easy as opening the CMakeLists.txt. I can only
>>recommend it.
>>Matthias
>>On Mit 10 Sep 2014 14:45:40 CEST, A Huarte wrote:
>>> Hi devs!, I am changing my SO from Windows to Linux Mint Debian
>>> Edition (LMDE).
>>> I have experience in Windows using Visual Studio, but I newbie in this
>>> Linux platform, which IDE do you believe it is better to develop QGIS
>>> (or C ++ in general) ?
>>> Qt Creator, Eclipse CDT, dev-c++ ?
>>> Thank you very much!
>>> Best regards
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>Larry Shaffer
>Dakota Cartography
>Black Hills, South Dakota
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140910/d06b1392/attachment.html>
