[Qgis-developer] QGIS Server "Publish to Web" plugin
Marco Hugentobler marco.hugentobler at sourcepole.ch
Thu Sep 11 00:08:01 PDT 2014
Hi
Yes, the 'publish to web' plugin is from the time when QGIS server had
SLD as the only way of configuration (before 2009). Such a plugin could
still be usefull to upload svg images / local data to the server or to
replace db user/pw in the project file (but the old publish to web
plugin did only handle layers / datasources / symbology which is now
indeed covered by the project file).
Regards,
Marco
On 11.09.2014 08:56, René-Luc Dhont wrote:
> Hi Alessandro,
> I think that this plugin is not yet necessary, because QGIS project is
> the way to "Publish to Web". No need to export the project to a SLD
> configuration file like in the youth of QGIS-Server.
> Marco can confirm it, isn't it ?
> René-Luc
> Le 10/09/2014 09:38, Alessandro Pasotti a écrit :
>> Hi,
>> I was reading the docs here:
>> http://docs.qgis.org/2.0/en/docs/user_manual/working_with_ogc/ogc_server_support.html
>> it says:
>> Moreover, the QGIS Server project provides the ‘Publish to Web’
>> plugin, a plugin for QGIS desktop which exports the current layers and
>> symbology as a web project for QGIS Server (containing cartographic
>> visualization rules expressed in SLD).
>> Is that still true?
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
