[Qgis-developer] QGIS Server "Publish to Web" plugin
Alessandro Pasotti
apasotti at gmail.com
Thu Sep 11 00:16:13 PDT 2014
Removed that fossil:
https://github.com/qgis/QGIS-Documentation/pull/253
2014-09-11 9:08 GMT+02:00 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
> Hi
> Yes, the 'publish to web' plugin is from the time when QGIS server had SLD
> as the only way of configuration (before 2009). Such a plugin could still be
> usefull to upload svg images / local data to the server or to replace db
> user/pw in the project file (but the old publish to web plugin did only
> handle layers / datasources / symbology which is now indeed covered by the
> project file).
> Regards,
> Marco
> On 11.09.2014 08:56, René-Luc Dhont wrote:
>> Hi Alessandro,
>> I think that this plugin is not yet necessary, because QGIS project is the
>> way to "Publish to Web". No need to export the project to a SLD
>> configuration file like in the youth of QGIS-Server.
>> Marco can confirm it, isn't it ?
>> René-Luc
>> Le 10/09/2014 09:38, Alessandro Pasotti a écrit :
>>> Hi,
>>> I was reading the docs here:
>>> http://docs.qgis.org/2.0/en/docs/user_manual/working_with_ogc/ogc_server_support.html
>>> it says:
>>> Moreover, the QGIS Server project provides the ‘Publish to Web’
>>> plugin, a plugin for QGIS desktop which exports the current layers and
>>> symbology as a web project for QGIS Server (containing cartographic
>>> visualization rules expressed in SLD).
>>> Is that still true?
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
Alessandro Pasotti
w3: www.itopen.it
