[Qgis-developer] Rotating point symbols
Andreas Neumann a.neumann at carto.net
Wed Sep 17 06:07:19 PDT 2014
Apparently the "Point rotation" tool is still available (at the end of
the "advanced digitizing toolbar"), but it is not compatible with the
rule-based renderer ;-( If I use a classified renderer or a single
simple renderer I can choose the rotation field.
Maybe we could fix this at the hackfest?
Thanks,
Andreas
Am 17.09.2014 12:57, schrieb Andreas Neumann:
> Hi,
> In an old QGIS version (can't remember which (probably pre QGIS 2.0)) we
> had a tool to rotate point symbols, if a column storing rotation values
> was correctly specified. It even had fixed rotation steps (every 15
> degrees) when pressing a modifier key (I think the alt-key).
> In a current QGIS version I can only edit rotation values manually in a
> widget, but not interactively on the map canvas.
> There is a rotation tool active in the "Advanced digitizing toolbar",
> but this seems to work only for polygon or linestring features and not
> for points.
> Anyone knows what happened to the interactive point rotation tool? Why
> did it disappear? We need this back - interactive rotation is more
> intuitive than rotation by manually changing rotation values in a form.
> Thanks,
> Andreas
> Qgis-developer mailing list
