[Qgis-developer] Lizmap edit layer
Mira Maric mmmxxxm at gmail.com
Fri Sep 19 12:15:12 PDT 2014
Hi. I am using lizmap web client form editing layer bus_stops.
Bus_stops layer is in Postgis database. I am import it to the database
from the shapefile with SPIT plugin.
When I try to edit layer with lizmap webclient I get next message:
An error occured for : 'SELECT *, ST_AsText() AS astext FROM
"topology"."bus_stops" WHERE ST_Intersects(
ST_MakeEnvelope(429253.865738,5407067.308823,429265.809023,5407079.252109,
3857 ), ST_Transform(, 3857 ) )', the message:invalid query (ERROR:
syntax error at or near ","
