[Qgis-developer] QGIS sometimes freezes in Windows 7 x64
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Sep 22 01:59:50 PDT 2014
Hi Casper,
I know it is hard to track down a problem if you cannot reproduce the
crash so the strategy would be to
* _either_ move all shape files to a local drive, continue working with
that and see if it does not crash any more
* _or_ disable multi-threaded rendering, continue working with that and
Bernhard
Am 22.09.2014 10:43, schrieb Casper Børgesen (CABO):
> Hi Bernhard.
> My shapefiles are indeed on a network drive, and it might be a timeout or similar causing the crash.
> I can disable threaded rendering, but as long as I cannot reproduce the crash, I cannot test if it works :)
> I have dragged my QGIS message window outside the QGIS window and I hope to be able to see the messages added when QGIS stops responding.
> Regards, Casper
> -----Original Message-----
> From: Bernhard Ströbl [mailto:bernhard.stroebl at jena.de]
> Sent: 22. september 2014 10:39
> To: Casper Børgesen (CABO); qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] QGIS sometimes freezes in Windows 7 x64
> Hi Casper,
> are these shapefiles on a local or network drive?
> Follow Andreas hint to disable multi-threaded renderin and see if it helps.
> Shapefiles on network drives are known to be slow, maybe this plus multi-threaded rendering causes the crash.
> Bernhard
> Am 22.09.2014 10:24, schrieb Casper Børgesen (CABO):
>> Hi Bernhard.
>> I cannot reproduce my issue and it doesn't seem related to loading.
>> My project consists of:
>> - No raster
>> - Shapefiles only
>> - Rule based styling
>> - No groups
>> Though our setups are very different, the issues could be related. If I could reproduce the issue, it would be a lot easier to report it.
>> I can see the see the yellow balloon tip informing me of messages added to the message window just before QGIS stops responding. But I can't see the messages since QGIS is not responding.
>> Regards Casper
>> From: qgis-developer-bounces at lists.osgeo.org
>> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Bernhard
>> Ströbl
>> Sent: 22. september 2014 10:09
>> To: qgis-developer at lists.osgeo.org
>> Hi Casper,
>> please check if your problem is related with this [1] issue and if yes report any additional infromation there.
>> [1] http://hub.qgis.org/issues/11141
>> Bernhard
>> Am 22.09.2014 09:55, schrieb Casper Børgesen (CABO):
>>> Too often QGIS 2.5 weekly (it happens in 2.4 too) tends to freeze
>>> while drawing the layers. It normally happens when I move around or
>>> zoom out, but I think it can happen when displaying a layer after
>>> loading it). So I guess it has something to do with drawing data or
>>> accessing data from the source.
>>> I would like to report this issue (or these issues), but I am not
>>> ready to begin debugging QGIS yet.
>>> How can I best help you devs in investigating the issue?
>>> -Is there a log file I can gain anything from?
>>> -I don't get any messages about a minidump.
>>> -QGIS is not responding, so I can't access the message log.
>>> -Normally QGIS doesn't return to a working/responding state.
>>> My OS is Windows 7 x64 and QGIS is 2.5.0-37 weekly (e46aa62).
>>> Regards Casper
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 10446 (20140921) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> http://www.eset.com
>> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 10447 (20140922) __________
http://www.eset.com
