[Qgis-developer] Lizmap edit layer
kimaidou
kimaidou at gmail.com
Mon Sep 22 04:54:32 PDT 2014
Hi ,
It seems Lizmap cannot find out which column is the geometry column. Could
you save the layer in QGIS via Menu > Layer > Save as Layer Definition
File, open this file with a text editor, delete the password and host
(found in the <datasource> element ) and send it to me by email, so that I
can see the datasource ?
Thanks in advance
Michael
2014-09-20 11:43 GMT+02:00 Salvatore Larosa <lrssvtml at gmail.com>:
> Hi,
> On Sat, Sep 20, 2014 at 11:06 AM, Mira Maric <mmmxxxm at gmail.com> wrote:
> > Hi. Same thing is when I save table in public schema or other schema.
> > When I run:
> > SELECT type FROM geometry_columns WHERE f_table_name = 'bus_stops' AND
> > f_table_schema = 'topology'
> > I get
> > Type character varying (30)
> > POINT
> that is ok, and which QGIS and LizMapWC versions?
> Could you provide the name of the geometry column in bus_stops table?
> I don't see the geometry column name either in ST_AsText or
> ST_Trasform, so it raises to
> syntax error when you are editing the bus_stops table from the web client.
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140922/85d8355a/attachment.html>
