[Qgis-developer] crash with undo command
Nejia nejia at spaceyes.fr
Wed Sep 24 08:08:36 PDT 2014
I have a plugin that allows to change an attribute value of added feature to
the selected value of a combo-box.
I change the attribute when the signal "featureAdded" is emmited (ie. Before
the endEditCommand of "add feature" is called) so in this undo command we
have in the order:
1-  QgsVectorLayerUndoCommandAddFeature
2-      QgsVectorLayerUndoCommandChangeAttribute
If we undo "add feature" command it must call undo() on all child commands
in reverse order, but when I debug in QGIS it do it in the order not in
reverse order ie. It call:
1-  QgsVectorLayerUndoCommandAddFeature::undo()
2-      QgsVectorLayerUndoCommandChangeAttribute::undo()
That's why Qgis crash when I undo "add feature" command
An explanation for this?
Is there any way to knew if the signal "feature added" is emitted when a new
feature is added not from commitChanges(), redoEditCommand() and
undoEditCommand()?
Thank you
Nejia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140924/02c1bbeb/attachment.html>
