Hi Andreas On 24.09.2014 17:55, Andreas Neumann wrote: > Thank you Matthias for the very quick fix. > > This fix only changes the NULL value behavior of the widget - right? > > This will probably have no effect on what QGIS server does with NULL > values, right? Correct, it's just representation on forms. -- Matthias
