[Qgis-developer] Memory Layers - some proposals
Andreas Neumann
a.neumann at carto.net
Wed Sep 24 23:50:56 PDT 2014
As a name, I like "Scratch layer" or "Temporary layer". I see that
people can confuse "Memory" with "permant storage".
Andreas
Am 25.09.2014 06:41, schrieb Nathan Woodrow:
> I guess the main issue with replacing the style swatch is we loose that
> for a ram icon that will be there all the time so you can't see the
> style set on the layer.
> Personally I do prefer the name Temporary rather then Memory.
> - Nathan
> On Thu, Sep 25, 2014 at 4:38 PM, Nyall Dawson <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
> On 25/09/2014 4:27 pm, "Mathieu Pellerin" <nirvn.asia at gmail.com
> <mailto:nirvn.asia at gmail.com>> wrote:
> > Possibly although that'd clutter that space.
> Not really- it could be handled in the same way as the editing icon
> is at the moment. That doesn't take up any extra room as it replaces
> the style swatch.
> > That said, I must say I quite enjoy using the memory layer saver, I'd be sad to see this function not making it into core.
> > Martin raised an important issue re format. What about saving memory layer data as GeoJSON within the qgis project file? That's a solution that is compatible with the project file's xml format.
> I think the issue is more with compatibility with other programs.
> That's why a zip/archive style project file which stores memory
> layers in an existing standard format (eg geojson) was suggested.
> Nyall
> Qgis-developer mailing list
