[Qgis-developer] Memory Layers - some proposals
Vincent Picavet vincent.ml at oslandia.com
Fri Sep 26 05:07:29 PDT 2014
Hi Nathan, all,
Le jeudi 25 septembre 2014 09:56:58, Nathan Woodrow a écrit :
> IMO we could in the future use sqlite in memory datastore for the memory
> provider which gives us a lot more options and range.
Hugo is currently writing a QEP to exactly do that and as well address some
issues regarding database features re-implementation.
He should publish it for review sooner or later.
This could help handle the memory layer topic, but actually is a wider issue.
Vincent
> Changing the format of the project file to something that isn't xml is a
> interesting idea however it's not something that should be rushed into
> without consideration so I think that is a very different topic.
> - Nathan
> On Thu, Sep 25, 2014 at 5:19 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> > Hi,
> > Please excuse my ignorance, but
> > Why would you want a memory (as in RAM) layer when you want permanent
> > data?
> > For portability reasons?
> > That's fine, but then we should offer a possibility to support
> > portability support for a real geo-format (with spatial index and all
> > the goodies). To stuff it into the project file there can be support
> > from a plugin, but I would not vote for adding this to core.
> > To me it seems that the current demand for this comes mainly from wrong
> > expectations created by the name (and people subsequently loosing data).
> > And we can fix the name.
> > For the portability issue, I'd rather go the longer way but get it right.
> > Regards
> > Matthias
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
