[Qgis-developer] Print composer in master
Ramon AndiƱach custard at westnet.com.au
Tue Sep 30 01:27:55 PDT 2014
Ah. A hidden change.
I'm following my established work flow.  Blank, then the toolbar folder icon, which now tells me it's "Load items from Template", except that because this is what I've always done, I didn't hang around long enough to see.
It's the same icon in the same place as the icon in 2.4 which identifies itself as "Load from Template".
I expected it to behave the same way on both versions.
I see that if I go into the menu and choose New from template I get what I'm expecting.
What's the difference between "add items from" and "new from" meant to be?
I'd prefer New from Template to be on the toolbar than add items, so I'm now curious about the change?
Is it possible to get back?
At the same time I see that the change means that now the icons map correctly between the toolbar and the menu, and that the new from template icon can't be on the toolbar without confusion.
-ramon.
> On 30 Sep 2014, at 15:44, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On 30 September 2014 15:52, Ramon AndiƱach <custard at westnet.com.au> wrote:
>> Hi,
>> I've opened up a couple of new issues in the tracker regarding the Print Composer in Master.
>> The Print Composer is currently ignoring the page orientation in my templates, with flow on effects.
>> http://hub.qgis.org/issues/11292
> Ramon,
> I've removed this issue as it's a duplicate of #11255. I'm after some
> more details on this one though - are you able to confirm the steps
> you do to make the new composition from a template? Specifically, are
> you creating a blank composition and using the "Add items from
> template" command, or using the composer manager to create new
> composition based off a template?
> Nyall
