[Qgis-developer] Print composer in master
Pedro Venâncio
pedrongvenancio at gmail.com
Tue Sep 30 01:51:06 PDT 2014
Ok, I also did not realize this change. This makes sense to me, but icons
do not seem very explicit. "New from template" icon is the same of "New
composer". And "Add items from template" has the same icon that in previous
versions were used to "Open" previously saved templates. So, it seems to me
that should change the icons in any way.
2014-09-30 9:34 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> I correct myself slightly: it may make sense to add "New from Template" to
> the toolbar, for those using the toolbar instead of the menu.
> Andreas
> On 30.09.2014 10:32, Andreas Neumann wrote:
>> Hi Ramon,
>> The difference is:
>> "New from template" overrides everything (including your page settings)
>> you had in your layout, and "Add items from template" leaves the page
>> settings and already existing items in place and just adds additional items
>> from a template.
>> I think that this distinction makes sense and is already clear enough for
>> the average user. No need to change anything.
>> Andreas
>> On 30.09.2014 10:27, Ramon Andiñach wrote:
>>> Ah. A hidden change.
>>> I'm following my established work flow. Blank, then the toolbar folder
>>> icon, which now tells me it's "Load items from Template", except that
>>> because this is what I've always done, I didn't hang around long enough to
>>> see.
>>> It's the same icon in the same place as the icon in 2.4 which identifies
>>> itself as "Load from Template".
>>> I expected it to behave the same way on both versions.
>>> I see that if I go into the menu and choose New from template I get what
>>> I'm expecting.
>>> What's the difference between "add items from" and "new from" meant to
>>> be?
>>> I'd prefer New from Template to be on the toolbar than add items, so I'm
>>> now curious about the change?
>>> Is it possible to get back?
>>> At the same time I see that the change means that now the icons map
>>> correctly between the toolbar and the menu, and that the new from template
>>> icon can't be on the toolbar without confusion.
>>> -ramon.
>>> On 30 Sep 2014, at 15:44, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>>> On 30 September 2014 15:52, Ramon Andiñach <custard at westnet.com.au>
>>>>> wrote:
>>>>> Hi,
>>>>> I've opened up a couple of new issues in the tracker regarding the
>>>>> Print Composer in Master.
>>>>> The Print Composer is currently ignoring the page orientation in my
>>>>> templates, with flow on effects.
>>>>> http://hub.qgis.org/issues/11292
>>>> Ramon,
>>>> I've removed this issue as it's a duplicate of #11255. I'm after some
>>>> more details on this one though - are you able to confirm the steps
>>>> you do to make the new composition from a template? Specifically, are
>>>> you creating a blank composition and using the "Add items from
>>>> template" command, or using the composer manager to create new
>>>> composition based off a template?
>>>> Nyall
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140930/dea576b8/attachment.html>
