[Qgis-developer] Print composer in master
Andreas Neumann
a.neumann at carto.net
Tue Sep 30 01:57:23 PDT 2014
agreed - can you contribute better icons? I am sure that the devs would
include that, if contributed.
Andreas
On 30.09.2014 10:51, Pedro Venâncio wrote:
> Ok, I also did not realize this change. This makes sense to me, but
> icons do not seem very explicit. "New from template" icon is the same
> of "New composer". And "Add items from template" has the same icon
> that in previous versions were used to "Open" previously saved
> templates. So, it seems to me that should change the icons in any way.
> 2014-09-30 9:34 GMT+01:00 Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>>:
> I correct myself slightly: it may make sense to add "New from
> Template" to the toolbar, for those using the toolbar instead of
> the menu.
> Andreas
> On 30.09.2014 10:32, Andreas Neumann wrote:
> Hi Ramon,
> The difference is:
> "New from template" overrides everything (including your page
> settings) you had in your layout, and "Add items from
> template" leaves the page settings and already existing items
> in place and just adds additional items from a template.
> I think that this distinction makes sense and is already clear
> enough for the average user. No need to change anything.
> Andreas
> On 30.09.2014 10:27, Ramon Andiñach wrote:
> Ah. A hidden change.
> I'm following my established work flow. Blank, then the
> toolbar folder icon, which now tells me it's "Load items
> from Template", except that because this is what I've
> always done, I didn't hang around long enough to see.
> It's the same icon in the same place as the icon in 2.4
> which identifies itself as "Load from Template".
> I expected it to behave the same way on both versions.
> I see that if I go into the menu and choose New from
> template I get what I'm expecting.
> What's the difference between "add items from" and "new
> from" meant to be?
> I'd prefer New from Template to be on the toolbar than add
> items, so I'm now curious about the change?
> Is it possible to get back?
> At the same time I see that the change means that now the
> icons map correctly between the toolbar and the menu, and
> that the new from template icon can't be on the toolbar
> without confusion.
> -ramon.
> On 30 Sep 2014, at 15:44, Nyall Dawson
> <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
> On 30 September 2014 15:52, Ramon Andiñach
> <custard at westnet.com.au
> <mailto:custard at westnet.com.au>> wrote:
> Hi,
> I've opened up a couple of new issues in the
> tracker regarding the Print Composer in Master.
> The Print Composer is currently ignoring the page
> orientation in my templates, with flow on effects.
> http://hub.qgis.org/issues/11292
> Ramon,
> I've removed this issue as it's a duplicate of #11255.
> I'm after some
> more details on this one though - are you able to
> confirm the steps
> you do to make the new composition from a template?
> Specifically, are
> you creating a blank composition and using the "Add
> items from
> template" command, or using the composer manager to
> create new
> composition based off a template?
> Nyall
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140930/7291483f/attachment-0001.html>
