[Qgis-developer] Thoughts about multi-type tables in QGIS
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Apr 2 07:41:56 PDT 2015
As an old MapInfo user/developer my opion is: Don't do it. It has always
been a problem in MapInfo and it will be a problem in QGIS - if
implemented.
A better approach is to have the possibility to let different QGIS
layers share some common characteristics (for example labelling). And -
of course - clean up the current errors in QGIS when splitting contents
of data sources by object types.
Regards
Bo Victor Thomsen
AestasGIS
Denmark
Den 02-04-2015 kl. 13:52 skrev Olivier Dalang:
> Hi,
> In some projects of mine, I work with multiple geometry types in one
> postgis table, using a column of type geometry(Geometry,4326).
> This is very well supported by postgis.
> It is possible to load such a table in QGIS by manually selecting the
> geometry type you want to load. This means that to display all the
> features, you need to add the table three times, one for each feature
> type.
> This works more or less. There are a few bugs though :
> - http://hub.qgis.org/issues/12499 (you can edit other type's node
> with the node tool)
> - http://hub.qgis.org/issues/12500 (other type's records are shown in
> the attribute table)
> This also has some limitations. When having such a setup, it's pretty
> sure you'll want to have the same edit forms for all the layers.
> You'll also probably want the same filter, the same labels, the same
> actions, etc...
> The only thing you'd want to be able to define on a geometry type
> basis are the symbol (well, even the classification/colors/etc could
> be shared) and the label placement.
> For now, you must do all settings three times, because of this
> bug/feature request :
> - http://hub.qgis.org/issues/12303 (copy/paste style from one geometry
> type to another)
> As you see, support multiple geometry types in QGIS is not perfect.
> Of course it's possible to fix the bugs/pr, and there are some
> workarounds (postgis view instead of tables) but maybe it's also worth
> thinking a bit more in depth about this.
> We could consider point/line/polygons as subcategories/sublayers of a
> layer. A shapefile or a mono-typed table would have only one of those
> sublayer, but a postgis table could perfectly have the three. Most of
> the settings would be defined at the layer level, while only some
> settings would be defined at the subcategory level.
> This is probably especially relevant when thinking long term (the day
> we support 3D, curves, etc...).
> What do you think ?
> Do you think the relation 1 layer = 1 geometry type will hold ?
> I think we inherited this from the old shapefile format, but most data
> sources QGIS handles don't have this limitation. I also think it does
> not hold with quite a lot of modern GIS uses (especially web related,
> think of openstreetmaps for instance).
> There's this feature request (6th oldest open issue on the tracker)
> about postgis geometry collections  : http://hub.qgis.org/issues/167
> Best,
> Olivier
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150402/b59a2f9b/attachment-0001.html>
