[Qgis-developer] Thoughts about multi-type tables in QGIS
Matthias Kuhn
matthias at opengis.ch
Thu Apr 2 05:59:12 PDT 2015
I agree with Nathan, for algorithms, symbology and a lot of small things
it will become very complicated.
As an alternative approach, we could think about having some layer
settings defined on group level (and maybe even a merged attribute table
for the whole group). That would already make a lot of things easier to
configure for multiple layers at once. We could even mark such a group
as a "union layer group" or similar, so for algorithms that support this
kind of thing it would be possible to offer such a "union layer group"
as choice while all other things just continue to work.
Matthias
On 04/02/2015 02:30 PM, Nathan Woodrow wrote:
> I would not be in favour of supporting a many geometry type per layer
> type setup, it just makes things a heap more complicated IMO for
> little gain.
> Also makes your code a lot more complicated, you now have to check
> each geometry for type because you are never sure what you will get.
> MapInfo did this and it was more a pain then a feature.
> On Thu, 2 Apr 2015 10:11 pm Denis Rouzaud <denis.rouzaud at gmail.com
> <mailto:denis.rouzaud at gmail.com>> wrote:
> Hi Olivier,
> I think you can easily extend your reasoning to the support of
> multiple geometry columns in QGIS.
> I believe that this would come in QGIS at some point.
> If QGIS 3 is getting closer, our company will support this feature.
> As you suggest, the layer could have different geometry types
> and/or columns. This could be seen as sub-layer level for rendering:
> layer > geometry types/columns > symbology rules
> I suppose this is quite a big change. Many things depends on the
> geometry type in QGIS (like map map tools), and that would
> represent a large API break.
> But, on my side, I believe it's a logic evolution for QGIS.
> Best wishes,
> Denis
> On 04/02/2015 01:52 PM, Olivier Dalang wrote:
>> Hi,
>> In some projects of mine, I work with multiple geometry types in
>> one postgis table, using a column of type geometry(Geometry,4326).
>> This is very well supported by postgis.
>> It is possible to load such a table in QGIS by manually selecting
>> the geometry type you want to load. This means that to display
>> all the features, you need to add the table three times, one for
>> each feature type.
>> This works more or less. There are a few bugs though :
>> - http://hub.qgis.org/issues/12499 (you can edit other type's
>> node with the node tool)
>> - http://hub.qgis.org/issues/12500 (other type's records are
>> shown in the attribute table)
>> This also has some limitations. When having such a setup, it's
>> pretty sure you'll want to have the same edit forms for all the
>> layers. You'll also probably want the same filter, the same
>> labels, the same actions, etc...
>> The only thing you'd want to be able to define on a geometry type
>> basis are the symbol (well, even the classification/colors/etc
>> could be shared) and the label placement.
>> For now, you must do all settings three times, because of this
>> bug/feature request :
>> - http://hub.qgis.org/issues/12303 (copy/paste style from one
>> geometry type to another)
>> As you see, support multiple geometry types in QGIS is not perfect.
>> Of course it's possible to fix the bugs/pr, and there are some
>> workarounds (postgis view instead of tables) but maybe it's also
>> worth thinking a bit more in depth about this.
>> We could consider point/line/polygons as subcategories/sublayers
>> of a layer. A shapefile or a mono-typed table would have only one
>> of those sublayer, but a postgis table could perfectly have the
>> three. Most of the settings would be defined at the layer level,
>> while only some settings would be defined at the subcategory level.
>> This is probably especially relevant when thinking long term (the
>> day we support 3D, curves, etc...).
>> What do you think ?
>> Do you think the relation 1 layer = 1 geometry type will hold ?
>> I think we inherited this from the old shapefile format, but most
>> data sources QGIS handles don't have this limitation. I also
>> think it does not hold with quite a lot of modern GIS uses
>> (especially web related, think of openstreetmaps for instance).
>> There's this feature request (6th oldest open issue on the
>> tracker) about postgis geometry collections :
>> http://hub.qgis.org/issues/167
>> Best,
>> Olivier
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150402/fb00ce95/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150402/fb00ce95/attachment.pgp>
