[Qgis-developer] R: Re: committedGeometriesChanges issue
Enrico Fiore
enricofiore at libero.it
Fri Apr 10 00:02:45 PDT 2015
Hi Oliver,
----Messaggio originale----
Da: olivier.dalang at gmail.com
>Hi Enrico,
>The bug should fixed in master, did you update your 2.9 version to the
latest one ?
I tried committedGeometriesChanges also in QGIS 2.9 Master installed via
osgeo4w.
Can be that the method doesn't work because it is used in a openForm function,
and no form is open duringe the move point action?
Enrico
2015-04-08 15:32 GMT+02:00 Enrico Fiore <enricofiore at libero.it>:
I am trying to perform a post-processing queries in a postgis layer. When a
new point is insert all work fine, but if I move existing point the queries
don't work. The event committedGeometriesChanges seems that doesn't work.
Is it because is not open the form dialog to perform this action?
I found this thread
http://osgeo-org.1560.x6.nabble.com/Post-processing-queries-on-postgis-layers-
after-insert-delete-update-td5193956.html
where is written that it is a bug and that it is fixed in 65378e6
I tried both with QGIS 2.8.1 and QGIS 2.9.0.40.
Is it a mistake or the bug is not fixed? Is it necessary open a ticket?
The code that I use is
def formOpen(dialog, layerid, featureid):
layerid.commitedGeometriesChanges.connect(confirmChanged)
def confirmChanged(layerid, changedGeometries):
... update attribute with queries ....
Regards
Enrico Fiore
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
