[Qgis-developer] How to load a QLR file with pyQGIS ?
Gary Sherman
gsherman at geoapt.com
Wed Apr 15 09:39:21 PDT 2015
On 4/15/15 2:24 AM, Geo DrinX wrote:
> Hello,
> there is a way to load a QLR file with pyQGIS ?
> I tried using vlayer.loadNamedStyle(qlrFileName) but it seems
> not to work.
> What is the correct way ?
That is the correct way. Have you done the following after applying the
style?:
vlayer.triggerRepaint()
You can test the result of applying the style using:
result = vlayer.loadNamedStyle(qlrFileName)
If result if False, the style was not loaded/applied.
-gary
> Thank you
> Roberto
> Qgis-developer mailing list
Gary Sherman
Founder, QGIS Project
Consulting: geoapt.com
Publishing: locatepress.com
We work virtually anywhere
