[Qgis-developer] How to load a QLR file with pyQGIS ?
Geo DrinX geodrinx at gmail.com
Wed Apr 15 23:50:56 PDT 2015
Very strange   :(
I inserted also the    triggerRepaint()   but nothing changes.
This is my sourcecode:
https://github.com/geodrinx/smartroadsense/blob/master/smartroadsense.py
If I drag and drop in  QGIS  my  "srs_data.qlr"   file, it works.
Instead, from python code, the style is not applied.
Could be because my data file is a CSV ?
2015-04-15 18:39 GMT+02:00 Gary Sherman <gsherman at geoapt.com>:
> On 4/15/15 2:24 AM, Geo DrinX wrote:
>> Hello,
>> there is a way to load a QLR file with  pyQGIS ?
>> I tried using      vlayer.loadNamedStyle(qlrFileName)    but it seems
>> not to work.
>> What is the correct way ?
>>  That is the correct way. Have you done the following after applying the
> style?:
> vlayer.triggerRepaint()
> You can test the result of applying the style using:
> result = vlayer.loadNamedStyle(qlrFileName)
> If result if False, the style was not loaded/applied.
> -gary
>> Thank you
>> Roberto
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Gary Sherman
> Founder, QGIS Project
> Consulting: geoapt.com
> Publishing: locatepress.com
> We work virtually anywhere
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150416/e78adf33/attachment.html>
