[Qgis-developer] How to load a QLR file with pyQGIS ?
Nathan Woodrow
madmanwoo at gmail.com
Wed Apr 15 23:55:41 PDT 2015
Hey,
QLR files are not style files they can't be loaded like that.
Unfortunately the API for loading a QLR is broken in 2.8.1 but will be
fixed in 2.8.2, however the logic isn't very complex and you can translate
it to Python from C++. The source is here
https://github.com/qgis/QGIS/blob/master/src/core/qgslayerdefinition.cpp#L36
If you don't need to support loading groups from the QLR you can use this:
QList<QgsMapLayer*> layers = QgsMapLayer::fromLayerDefinition( doc );
QgsMapLayerRegistry::instance()->addMapLayers( layers, True);
- Nathan
On Thu, 16 Apr 2015 at 16:51 Geo DrinX <geodrinx at gmail.com> wrote:
> Very strange :(
> I inserted also the triggerRepaint() but nothing changes.
> This is my sourcecode:
> https://github.com/geodrinx/smartroadsense/blob/master/smartroadsense.py
> If I drag and drop in QGIS my "srs_data.qlr" file, it works.
> Instead, from python code, the style is not applied.
> Could be because my data file is a CSV ?
> 2015-04-15 18:39 GMT+02:00 Gary Sherman <gsherman at geoapt.com>:
>> On 4/15/15 2:24 AM, Geo DrinX wrote:
>>> Hello,
>>> there is a way to load a QLR file with pyQGIS ?
>>> I tried using vlayer.loadNamedStyle(qlrFileName) but it seems
>>> not to work.
>>> What is the correct way ?
>>> That is the correct way. Have you done the following after applying the
>> style?:
>> vlayer.triggerRepaint()
>> You can test the result of applying the style using:
>> result = vlayer.loadNamedStyle(qlrFileName)
>> If result if False, the style was not loaded/applied.
>> -gary
>>> Thank you
>>> Roberto
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Gary Sherman
>> Founder, QGIS Project
>> Consulting: geoapt.com
>> Publishing: locatepress.com
>> We work virtually anywhere
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150416/ff373eed/attachment.html>
