[Qgis-developer] ValueMap: Why is the first row of my ComboBox empty?
Matthias Kuhn
matthias at opengis.ch
Thu Apr 16 23:09:02 PDT 2015
Are you referring to identifying an existing feature or adding a new
feature?
For the first case, no row is selected if for the value of the
identified feature no entry can be found in the map. If it can be found
in the valuemap it should always select an entry. Please open a bug
report if you find a misbehavior here.
For the second case a default value would be good indeed.
Regards
Matthias
On 04/11/2015 11:39 PM, luna wrote:
> I define a field of a vector layer as ValueMap. I define the values manually,
> then the feature attribute dialog appears with the combobox. But the first
> row in my combobox is empty.
> I use QGis2.8. In QGis2.0 the first row was not empty.
> <http://osgeo-org.1560.x6.nabble.com/file/n5200932/1.jpg>
> <http://osgeo-org.1560.x6.nabble.com/file/n5200932/2.jpg>
> If I click "ok" immediately without using the combobox I get a strange
> character () in the attribut tablel.
> Regards
> View this message in context: http://osgeo-org.1560.x6.nabble.com/ValueMap-Why-is-the-first-row-of-my-ComboBox-empty-tp5200932.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150417/ef9d2870/attachment.pgp>
