[Qgis-developer] information stored in a project file (2.8)
Andreas Neumann
a.neumann at carto.net
Fri Apr 17 03:07:48 PDT 2015
And you can add
* Table Relations
* Project Macros
* Project default styles
* Which layers can be queried
* QGIS Server settings (the settings in the project settings tab -> OWS
tab).
The longer I think, the longer the list gets ;-) there is a lot of
information in the project file - basically everything except the raw data.
Note that should be "last viewed extent" (not extend).
Best greetings,
Andreas
On 17.04.2015 11:48, Denis Rouzaud wrote:
> I would add plugins settings, custom layer properties
> On 04/17/2015 11:36 AM, Larissa Junek wrote:
>> Hello,
>> I had a look at my *.qgs-files and so far I understand that there is
>> information stored about
>> * Layers added
>> * Layer properties, icluding symbolisation and styles
>> * Projection for the map view
>> * Last viewed extend
>> * Print Composers
>> * Print Composer elements with settings
>> * Print Composer atlas settings
>> * Digitizing settings
>> Did I miss something essential? I want to insert the descriptions into
>> the QGIS user manual 2.8.
>> Thanks in advance.
>> Kind regards,
>> Larissa
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
