[Qgis-developer] qgis-web-client: module wsgi
Bernhard Ströbl
bernhard.stroebl at jena.de
Wed Apr 22 01:22:01 PDT 2015
Hi Enzo,
I am no Apache pro at all :-)
My config additionally contains the following:
<Directory /path/to/wsgi>
Order allow,deny
Allow from all
</Directory>
I wonder if the user running the apache process can access /home/www,
normally you would use something like /var/www/wsgi or /srv/www/wsgi
similar to where your HTML stuff is (and QWC)
Bernhard
Am 22.04.2015 10:12, schrieb Enzo Cocca:
> Thanks Bernard
> You are right, but now It not found the path wsgi folder
> "The requested URL /wsgi/search.wsgi was not found on this server."
> in globalOptions. js I set :
> //URL for custom search scriptsnull; //
> var searchBoxQueryURL = "/wsgi/search.wsgi?query="; // null:
> var searchBoxGetGeomURL = "/wsgi/getSearchGeom.wsgi";//null; //
> and
> in /etc/apache2/sites-available/default
> I set
> #mod_wsgi
> WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
> WSGIScriptAlias /wsgi/ /home/www/wsgi/
> WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
> and than I restarted apache
> Where I wrong?
> 2015-04-22 11:26 GMT+04:00 Bernhard Ströbl <bernhard.stroebl at jena.de
> <mailto:bernhard.stroebl at jena.de>>:
> Hi Enzo,
> your error indicates that the script is not executed as a server
> script but instead delivered to the client. Thjis should not happen,
> as it is a high security risk (db internals are exposed).
> Have you enabled mod_wsgi on your apache server as described in
> section 6.2.1 of the QWC documentation?
> You also should follow this line (section 6 the documentation): "It
> is recommended to install the wsgi scripts in a separate directory,
> e.g. /home/www/wsgi, a place that is not reachable by regular web
> traffic."
> Bernhard
> Am 22.04.2015 09:15, schrieb Enzo Cocca:
> Tahnks Bernhard,
> I know, I have followed the procedure from official guideline
> https://github.com/qgis/QGIS-Web-Client
> but when execute a sample query in Firefox, like written in the
> search.wsgi file, Firefox only visualize the file search.wsgi like a
> text file.
> and I have the error
> "illegal character
> #!/usr/bin/python"
> So I not understand the problem....
> Thanks!!
> 2015-04-22 10:51 GMT+04:00 Bernhard Ströbl
> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>
> <mailto:bernhard.stroebl at jena.de>>>:
> Hi,
> the wsgi-Script is a script to be run _on the server_, not
> in the
> client.
> Bernhard
> Am 22.04.2015 08:47, schrieb Enzo Cocca:
> Hi,
> I have one questionç
> I try to write a searchtext in the client, Firebug
> gives the error
> message:
> "illegal character
> #!/usr/bin/python"
> Someone have a idea??
> thanks!!
> __________ Information from ESET Mail Security, version of
> virus
> signature database 11513 (20150422) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> <mailto:Qgis-developer at lists.osgeo.org>>
> __________ Information from ESET Mail Security, version of virus
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 11513 (20150422) __________
http://www.eset.com
