[Qgis-developer] qgis-web-client: module wsgi
Enzo Cocca
enzo.ccc at gmail.com
Wed Apr 22 01:59:30 PDT 2015
the config additional you write it in apache config or in default?
because if I add it in default, I have the same error.
I will try again. When I will find the solution i will let you know
Thanks a lot
EC
2015-04-22 12:22 GMT+04:00 Bernhard Ströbl <bernhard.stroebl at jena.de>:
> Hi Enzo,
> I am no Apache pro at all :-)
> My config additionally contains the following:
> <Directory /path/to/wsgi>
> Order allow,deny
> Allow from all
> </Directory>
> I wonder if the user running the apache process can access /home/www,
> normally you would use something like /var/www/wsgi or /srv/www/wsgi
> similar to where your HTML stuff is (and QWC)
> Bernhard
> Am 22.04.2015 10:12, schrieb Enzo Cocca:
>> Thanks Bernard
>> You are right, but now It not found the path wsgi folder
>> "The requested URL /wsgi/search.wsgi was not found on this server."
>> in globalOptions. js I set :
>> //URL for custom search scriptsnull; //
>> var searchBoxQueryURL = "/wsgi/search.wsgi?query="; // null:
>> var searchBoxGetGeomURL = "/wsgi/getSearchGeom.wsgi";//null; //
>> and
>> in /etc/apache2/sites-available/default
>> I set
>> #mod_wsgi
>> WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
>> WSGIScriptAlias /wsgi/ /home/www/wsgi/
>> WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
>> and than I restarted apache
>> Where I wrong?
>> 2015-04-22 11:26 GMT+04:00 Bernhard Ströbl <bernhard.stroebl at jena.de
>> <mailto:bernhard.stroebl at jena.de>>:
>> Hi Enzo,
>> your error indicates that the script is not executed as a server
>> script but instead delivered to the client. Thjis should not happen,
>> as it is a high security risk (db internals are exposed).
>> Have you enabled mod_wsgi on your apache server as described in
>> section 6.2.1 of the QWC documentation?
>> You also should follow this line (section 6 the documentation): "It
>> is recommended to install the wsgi scripts in a separate directory,
>> e.g. /home/www/wsgi, a place that is not reachable by regular web
>> traffic."
>> Bernhard
>> Am 22.04.2015 09:15, schrieb Enzo Cocca:
>> Tahnks Bernhard,
>> I know, I have followed the procedure from official guideline
>> https://github.com/qgis/QGIS-Web-Client
>> but when execute a sample query in Firefox, like written in the
>> search.wsgi file, Firefox only visualize the file search.wsgi
>> like a
>> text file.
>> and I have the error
>> "illegal character
>> #!/usr/bin/python"
>> So I not understand the problem....
>> Thanks!!
>> 2015-04-22 10:51 GMT+04:00 Bernhard Ströbl
>> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>
>> <mailto:bernhard.stroebl at jena.de>>>:
>> Hi,
>> the wsgi-Script is a script to be run _on the server_, not
>> in the
>> client.
>> Bernhard
>> Am 22.04.2015 08:47, schrieb Enzo Cocca:
>> Hi,
>> I have one questionç
>> I try to write a searchtext in the client, Firebug
>> gives the error
>> message:
>> "illegal character
>> #!/usr/bin/python"
>> Someone have a idea??
>> thanks!!
>> __________ Information from ESET Mail Security, version of
>> virus
>> signature database 11513 (20150422) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> <mailto:Qgis-developer at lists.osgeo.org>>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> __________ Information from ESET Mail Security, version of virus
>> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature
> http://www.eset.com
Enzo Cocca PhD
in "Science and Technology for Archaeology and Cultural Heritage"
mail: enzo.ccc at gmail.com
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150422/69a2ebd0/attachment.html>
