[Qgis-developer] (how) should multicore rendering work ?
Sandro Santilli strk at keybit.net
Wed Apr 22 09:19:56 PDT 2015
I noticed that even with "Render layers in parallel using many CPU cores"
checked and "Max cores to use" set to 8, my CPU monitor shows a single CPU
is used while a single ~8 millions PostGIS point rows are being rendered.
If I uncheck "Render layers in parallel using many CPU cores" nothing
changes. Is this normal/expected with a single layer ?
--strk;
