[Qgis-developer] Please check: I can't set selection color
Luigi Pirelli luipir at gmail.com
Wed Apr 22 10:06:51 PDT 2015
thank you Alessandro,
regards, Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Elance: https://www.elance.com/s/edit/luigipirelli/
* GitHub: https://github.com/luipir
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 22 April 2015 at 18:57, Alessandro Pasotti <apasotti at gmail.com> wrote:
> 2015-04-22 17:46 GMT+02:00 Luigi Pirelli <luipir at gmail.com>:
>> Hi
>> please check if it's a bug or my local problem... I can't change color
>> for selected features from GUI
>> I think the color for selected feature is set in:
>> project properties->general->selection color (I set it to green)
>> but when the feature is selected (linear o polygonal) it remain
>> yellow! also after saved the project and reloaded.
>> because of selection color is set in QgsMapSettings, seems there is
>> not relation with properties->general->selection configuration
>> parameter saved in the project.
>> QgsMapSettings are saved in qgis.ini file under Qgis section.
>> I'm on compiled 2.8.1, but the same happen in master code
> Hi Gino,
> I'am able to set selection color from  Project Properties -> General
> settings -> Selection color on both poly and points on latest master.
> Alessandro Pasotti
> w3:   www.itopen.it
