[Qgis-developer] Please check: I can't set selection color
Alessandro Pasotti
apasotti at gmail.com
Wed Apr 22 09:57:27 PDT 2015
2015-04-22 17:46 GMT+02:00 Luigi Pirelli <luipir at gmail.com>:
> Hi
> please check if it's a bug or my local problem... I can't change color
> for selected features from GUI
> I think the color for selected feature is set in:
> project properties->general->selection color (I set it to green)
> but when the feature is selected (linear o polygonal) it remain
> yellow! also after saved the project and reloaded.
> because of selection color is set in QgsMapSettings, seems there is
> not relation with properties->general->selection configuration
> parameter saved in the project.
> QgsMapSettings are saved in qgis.ini file under Qgis section.
> I'm on compiled 2.8.1, but the same happen in master code
Hi Gino,
I'am able to set selection color from Project Properties -> General
settings -> Selection color on both poly and points on latest master.
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150422/090a54a9/attachment.html>
