[Qgis-developer] qgis-web-client: module wsgi
Bernhard Ströbl
bernhard.stroebl at jena.de
Wed Apr 22 22:42:57 PDT 2015
Hi Enzo,
do not put it into html (see section 6 of the QWC documentation) maybe
in that location it is not run as a script but accessed by the browser
as any other html file (remember: I am no expert on this).
Basically you should not see the file at all in the browser, if an error
occurs it should be in Apache's error log.
Be sure ther is no space as the first character of the first line (as
was suggested before).
Bernhard
Am 22.04.2015 22:15, schrieb Enzo Cocca:
> I continue to have the problem with mod_wsgi module. I not
> understand.... I have set the apache config like suggest bernhard and
> I have put my wsgi folder in /var/www/html but I continue to have the error:
> illegal charcther #! /usr/bin/python
> I have reinstalled libapache2-mod-wsgi, but nothing
> I use ubuntu server 14.04 apache 2.4 python 2.7
> Thanks at all for help
> E
> 2015-04-22 16:32 GMT+04:00 Bernhard Ströbl <bernhard.stroebl at jena.de
> <mailto:bernhard.stroebl at jena.de>>:
> Hi Enzo,
> as I wrote in a previous post: Make sure the user running the apache
> process has access to the wsgi directory. Try putting the wsgi in
> /home/somthing e.g. in /var/www/wsgi
> Bernhard
> Am 22.04.2015 14:07, schrieb Enzo Cocca:
> Hi all,
> I looked for a solution but without results.
> After set the default file in apache like that:
> <VirtualHost *:80>
> ServerAdmin webmaster at localhost
> ServerName <localhost>
> DocumentRoot /var/www/html/wms/site
> <Directory />
> Options FollowSymLinks
> AllowOverride None
> </Directory>
> <Directory /var/www/html/wms/site/>
> DirectoryIndex index.php index.html
> Options Indexes FollowSymLinks MultiViews
> AllowOverride None
> Order allow,deny
> allow from all
> Require all granted
> </Directory>
> ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
> <Directory "/usr/lib/cgi-bin/">
> AllowOverride None
> Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
> Order allow,deny
> Allow from all
> Require all granted
> SetEnv QGIS_LOG_FILE /tmp/qgislog.txt
> </Directory>
> RewriteEngine On
> RewriteRule ^/cgi-bin/.*$ - [F]
> RewriteRule ^/wms/(.+)$
> /cgi-bin/qgis_mapserv.fcgi?map=/var/www/html/wms/projects/$1.qgs
> [QSA,PT]
> RewriteRule ^/maps/?$ / [PT]
> RewriteRule ^/maps/([^\.]+)$ /qgiswebclient.html [PT]
> RewriteRule ^/maps/(.*) /$1 [PT]
> #mod_wsgi
> #LoadModule wsgi_module /usr/lib/apache2/modules/mod_wsgi.so
> WSGIDaemonProcess gis processes=5 threads=15
> display-name=%{GROUP}
> WSGIScriptAlias /wsgi/ /home/www/wsgi/
> WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
> <Directory "/home/www/wsgi/">
> Order allow,deny
> Allow from all
> </Directory>
> ErrorLog ${APACHE_LOG_DIR}/qgis-web-client-error.log
> CustomLog ${APACHE_LOG_DIR}/qgis-web-client-access.log combined
> </VirtualHost>
> and the GlobaOptions.js like that;
> //URL for custom search scriptsnull; //
> var searchBoxQueryURL = "/wsgi/search.wsgi?query="; // null:
> var searchBoxGetGeomURL = "/wsgi/getSearchGeom.wsgi";//null; //
> The status is:
> NetworkError: 404 Not Found -
> http://localhost/wsgi/search.wsgi?query=&searchtables=&query=qqq&cb=stcCallback1001
> So it not found the path of wsgi, but in default config I have
> give the
> alias
> any idea?
> E
> __________ Information from ESET Mail Security, version of virus
> signature database 11515 (20150422) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
__________ Information from ESET Mail Security, version of virus signature database 11519 (20150423) __________
http://www.eset.com
