[Qgis-developer] Problem with addAttribute and Postgres default value
Luca Manganelli
luca76 at gmail.com
Wed Apr 22 23:25:08 PDT 2015
On Wed, Apr 22, 2015 at 4:15 PM, Luca Manganelli <luca76 at gmail.com> wrote:
> Hi,
> I have a spatial table with an attribute that uses the today's date as
> a default value.
I found myself the solution to the problem.
The trick is to check if the defaultValue() of the field is not null:
# Create new feature
new_feature = QgsFeature()
new_feature.initAttributes ( len ( layer.dataProvider().fieldNameMap() ) )
new_feature.setGeometry( ... )
# Populate fields with DEFAULT value in Postgres
new_attributes = layer.pendingFields()
for j in new_attributes:
fieldname = j.name()
fieldindex = layer.dataProvider().fieldNameIndex(fieldname)
fielddefault = layer.dataProvider().defaultValue(fieldindex)
if fieldindex == 0: # skip ogc_fid (mine is at index 0)
continue
if unicode (fielddefault) != "NULL":
new_feature.setAttribute (fieldindex, fielddefault)
# Populate your fields
new_feature.setAttribute ( ..., ... )
