[Qgis-developer] qgis-web-client: module wsgi
Andreas Neumann
a.neumann at carto.net
Thu Apr 23 13:22:13 PDT 2015
Hi Enzo,
This has nothing to do with QGIS. Please google something like "wsgi
Apache setup" - e.g.
https://code.google.com/p/modwsgi/wiki/QuickConfigurationGuide and make
sure you can handle your Apache setup. Make sure you can run the hello
world example listed in the modwsgi documentation.
Then you can continue to come back with QGIS server questions.
Andreas
On 23.04.2015 19:33, Enzo Cocca wrote:
> Hi Bernard,
> I have followed
> If I put the wsgi folder in /usr/lib/cgi-bin/ and set apache config like
> WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
> WSGIScriptAlias /wsgi/ /usr/lib/cgi-bin/wsgi/
> WSGIScriptAliasMatch ^/wsgi/([^/]+) /usr/lib/cgi-bin/wsgi/$1.wsgi
> I have internal error 500. You I'm not understand again
> sorry
> E
> 2015-04-23 9:42 GMT+04:00 Bernhard Ströbl <bernhard.stroebl at jena.de
> <mailto:bernhard.stroebl at jena.de>>:
> Hi Enzo,
> do not put it into html (see section 6 of the QWC documentation)
> maybe in that location it is not run as a script but accessed by
> the browser as any other html file (remember: I am no expert on this).
> Basically you should not see the file at all in the browser, if an
> error occurs it should be in Apache's error log.
> Be sure ther is no space as the first character of the first line
> (as was suggested before).
> Bernhard
> Am 22.04.2015 22:15, schrieb Enzo Cocca:
> I continue to have the problem with mod_wsgi module. I not
> understand.... I have set the apache config like suggest
> bernhard and
> I have put my wsgi folder in /var/www/html but I continue to
> have the error:
> illegal charcther #! /usr/bin/python
> I have reinstalled libapache2-mod-wsgi, but nothing
> I use ubuntu server 14.04 apache 2.4 python 2.7
> Thanks at all for help
> E
> 2015-04-22 16:32 GMT+04:00 Bernhard Ströbl
> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>
> <mailto:bernhard.stroebl at jena.de>>>:
> Hi Enzo,
> as I wrote in a previous post: Make sure the user running
> the apache
> process has access to the wsgi directory. Try putting the
> wsgi in
> /home/somthing e.g. in /var/www/wsgi
> Bernhard
> Am 22.04.2015 14:07, schrieb Enzo Cocca:
> Hi all,
> I looked for a solution but without results.
> After set the default file in apache like that:
> <VirtualHost *:80>
> ServerAdmin webmaster at localhost
> ServerName <localhost>
> DocumentRoot /var/www/html/wms/site
> <Directory />
> Options FollowSymLinks
> AllowOverride None
> </Directory>
> <Directory /var/www/html/wms/site/>
> DirectoryIndex index.php index.html
> Options Indexes FollowSymLinks MultiViews
> AllowOverride None
> Order allow,deny
> allow from all
> Require all granted
> </Directory>
> ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
> <Directory "/usr/lib/cgi-bin/">
> AllowOverride None
> Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
> Order allow,deny
> Allow from all
> Require all granted
> SetEnv QGIS_LOG_FILE /tmp/qgislog.txt
> </Directory>
> RewriteEngine On
> RewriteRule ^/cgi-bin/.*$ - [F]
> RewriteRule ^/wms/(.+)$
> /cgi-bin/qgis_mapserv.fcgi?map=/var/www/html/wms/projects/$1.qgs
> [QSA,PT]
> RewriteRule ^/maps/?$ / [PT]
> RewriteRule ^/maps/([^\.]+)$ /qgiswebclient.html [PT]
> RewriteRule ^/maps/(.*) /$1 [PT]
> #mod_wsgi
> #LoadModule wsgi_module
> /usr/lib/apache2/modules/mod_wsgi.so
> WSGIScriptAlias /wsgi/ /home/www/wsgi/
> /home/www/wsgi/$1.wsgi
> <Directory "/home/www/wsgi/">
> Order allow,deny
> Allow from all
> </Directory>
> ErrorLog ${APACHE_LOG_DIR}/qgis-web-client-error.log
> CustomLog
> ${APACHE_LOG_DIR}/qgis-web-client-access.log combined
> </VirtualHost>
> and the GlobaOptions.js like that;
> //URL for custom search scriptsnull; //
> var searchBoxQueryURL = "/wsgi/search.wsgi?query="; //
> null:
> var searchBoxGetGeomURL =
> "/wsgi/getSearchGeom.wsgi";//null; //
> The status is:
> NetworkError: 404 Not Found -
> http://localhost/wsgi/search.wsgi?query=&searchtables=&query=qqq&cb=stcCallback1001
> So it not found the path of wsgi, but in default
> config I have
> give the
> alias
> any idea?
> E
> __________ Information from ESET Mail Security, version of
> virus
> signature database 11515 (20150422) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> <mailto:Qgis-developer at lists.osgeo.org>>
> __________ Information from ESET Mail Security, version of virus
> signature database 11519 (20150423) __________
> http://www.eset.com
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> Enzo Cocca PhD
> in "Science and Technology for Archaeology and Cultural Heritage"
> mail: enzo.ccc at gmail.com <mailto:enzo.ccc at gmail.com>
> cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150423/d2099d7e/attachment.html>
