[Qgis-developer] processing 'Import Vector into PostGIS database (available connections)'
Larissa Junek junek at gbd-consult.de
Wed Apr 29 02:44:15 PDT 2015
Hello,
is there someone with experience in using the processing GDAL 'Import
Vector into PostGIS database (available connections)' algorithm?
I have problems with the authentication to the PostGIS database and
look for a workflow which can be inserted into the user manual then.
Kind regards,
Larissa
