[Qgis-developer] Certificate update QGIS servers
Alex Mandel
tech_dev at wildintellect.com
Thu Aug 6 21:10:27 PDT 2015
On 08/06/2015 09:51 AM, Alex Mandel wrote:
> On 08/06/2015 03:29 AM, Richard Duivenvoorde wrote:
>> Hi,
>> FYI we updated the certificates for
>> hub.qgis.org
>> plugins.qgis.org
>> While I was pretty sure we scored an A on
>> https://www.ssllabs.com/ssltest/index.html
>> Now hub (on osgeo) scores a C, while plugins (qgis2) still scores an A...
>> both apache servers share the same config (but different versions of Apache)
> Are you sure it's the same config? It might be just a few extra ciphers
> in the SSL config that should be disabled for known security reasons.
> The SSL lab test usually tells you exactly why you scored low.
Looking at the report I am correct, it's just some tweaks to be made to
the SSL config on apache. The newer sites don't have this issue because
the defaults on newer Debian versions are safer.
This server supports weak Diffie-Hellman (DH) key exchange parameters.
Grade capped to B. MORE INFO »
The server supports only older protocols, but not the current best TLS
1.2. Grade capped to C. MORE INFO »
The server does not support Forward Secrecy with the reference browsers.
MORE INFO »
I'll try to make some fixes to it this weekend.
-Alex
