[Qgis-developer] Building plugin for Print Composer
Nyall Dawson
nyall.dawson at gmail.com
Sat Aug 8 02:19:42 PDT 2015
On 7 Aug 2015 6:58 pm, "Vincent Mora" <vincent.mora at oslandia.com> wrote:
> Hi all,
> I need to add graphs generated by a plugin to compositions. I'm
considering to develop a PluginComposerItem in the same spirit as
PluginLayers, adding/removing a button in the toolbar when the plugin is
registered/removed.
Just a warning that similar work is already underway - adding a composer
item type registry so that plugins can register their own custom item
types.
It's an extensive work though, because composer has a lot of hard coded
handling of all the existing item types (checkout all the item specific
methods in QgsComposition/QgsComposerView). That's why this work is tied up
with the layouts/reporting framework refactor.
Nyall
> Is that what was needed in your cases, or was a more general approach
required (like the qgis plugin mechanism, being able to access the
interface) ?
> V.
> Le 22/06/2015 18:05, G. Allegri a écrit :
>> The suggestion from John is exactly what we did too. And we also built a
chart composer...
>> It would be great to have the means to know what other teams are working
to. It would save a lor of time and money and, probably, get better
software from a shared effort ;)
>> giovanni
>> Il 22/giu/2015 19:31, "John Gitau" <gkahiu at gmail.com> ha scritto:
>>> Hi Jakob,
>>> A workaround would be to have a plugin that creates a new composer view
object:
>>> custom_composer = self.iface.createNewComposer("My Composer")
>>> Then get a reference to the main window in the composer view:
>>> main_window = custom_composer.composerWindow()
>>> Then you can either add a new toolbar (and required actions) or append
an action to the main toolbar. Have a look at the ComposerWrapper class for
something similar we implemented for designing charts in the composer:
https://gist.github.com/gkahiu/06a43a589f9441736397
>>> Hope this is helpful.
>>> Cheers,
>>> John
>>> On Mon, Jun 22, 2015 at 2:07 PM, G. Allegri <giohappy at gmail.com> wrote:
>>>> You can act on it but you can't custom gui widgets to the Composer
interface.
>>>> I cannot check the code right know. I listen to a specific (existing)
composition opening but if I remember correctly you can watch the Composer
opening too.
>>>> Il 22/giu/2015 17:19, "Jakob Lanstorp" <jlanstorp at gmail.com> ha
scritto:
>>>>> Hi Giovanni, thanks for the update. Another solution would be to
catch the
>>>>> event when a user starts an existing print composer. Cannot in doc
for the
>>>>> pyqgis API find anything for this. Anyone who know is one can listens
for a
>>>>> print composer to startup by the user and act on it.
>>>>> Jakob Lanstorp
>>>>> View this message in context:
http://osgeo-org.1560.x6.nabble.com/Building-plugin-for-Print-Composer-tp5212187p5212221.html
>>>>> Sent from the Quantum GIS - Developer mailing list archive at
Nabble.com.
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150808/319ea1cc/attachment.html>
