[Qgis-developer] Building plugin for Print Composer
G. Allegri
giohappy at gmail.com
Wed Aug 12 10:09:17 PDT 2015
We have talked a lot with Nyall about this. It was a requirement for a work
I was developing some months ago (it's what I was describing some emails
ago in this thead).
I suppose the work Nyall is talking about is the deep refactoring of the
Composer which will converge in the Report engine (QGIS > 3.x), is it right?
giovanni
2015-08-08 11:19 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 7 Aug 2015 6:58 pm, "Vincent Mora" <vincent.mora at oslandia.com> wrote:
> > Hi all,
> > I need to add graphs generated by a plugin to compositions. I'm
> considering to develop a PluginComposerItem in the same spirit as
> PluginLayers, adding/removing a button in the toolbar when the plugin is
> registered/removed.
> Just a warning that similar work is already underway - adding a composer
> item type registry so that plugins can register their own custom item
> types.
> It's an extensive work though, because composer has a lot of hard coded
> handling of all the existing item types (checkout all the item specific
> methods in QgsComposition/QgsComposerView). That's why this work is tied up
> with the layouts/reporting framework refactor.
> Nyall
> > Is that what was needed in your cases, or was a more general approach
> required (like the qgis plugin mechanism, being able to access the
> interface) ?
> > V.
> > Le 22/06/2015 18:05, G. Allegri a écrit :
> >> The suggestion from John is exactly what we did too. And we also built
> a chart composer...
> >> It would be great to have the means to know what other teams are
> working to. It would save a lor of time and money and, probably, get better
> software from a shared effort ;)
> >> giovanni
> >> Il 22/giu/2015 19:31, "John Gitau" <gkahiu at gmail.com> ha scritto:
> >>> Hi Jakob,
> >>> A workaround would be to have a plugin that creates a new composer
> view object:
> >>> custom_composer = self.iface.createNewComposer("My Composer")
> >>> Then get a reference to the main window in the composer view:
> >>> main_window = custom_composer.composerWindow()
> >>> Then you can either add a new toolbar (and required actions) or append
> an action to the main toolbar. Have a look at the ComposerWrapper class for
> something similar we implemented for designing charts in the composer:
> https://gist.github.com/gkahiu/06a43a589f9441736397
> >>> Hope this is helpful.
> >>> Cheers,
> >>> John
> >>> On Mon, Jun 22, 2015 at 2:07 PM, G. Allegri <giohappy at gmail.com>
> wrote:
> >>>> You can act on it but you can't custom gui widgets to the Composer
> interface.
> >>>> I cannot check the code right know. I listen to a specific (existing)
> composition opening but if I remember correctly you can watch the Composer
> opening too.
> >>>> Il 22/giu/2015 17:19, "Jakob Lanstorp" <jlanstorp at gmail.com> ha
> scritto:
> >>>>> Hi Giovanni, thanks for the update. Another solution would be to
> catch the
> >>>>> event when a user starts an existing print composer. Cannot in doc
> for the
> >>>>> pyqgis API find anything for this. Anyone who know is one can
> listens for a
> >>>>> print composer to startup by the user and act on it.
> >>>>> Jakob Lanstorp
> >>>>> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Building-plugin-for-Print-Composer-tp5212187p5212221.html
> >>>>> Sent from the Quantum GIS - Developer mailing list archive at
> Nabble.com.
> >>>>> _______________________________________________
> >>>>> Qgis-developer mailing list
> >>>>> Qgis-developer at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Giovanni Allegri
http://about.me/giovanniallegri
Gis3W - http://gis3w.it
Ikare - http://ikare.it
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150812/116382d6/attachment.html>
